1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
geographical location?
Discussion in 'Webhosting' started by yeahdude, Sep 21, 2005.
  1. yeahdude
    yeahdude New Member
    What are the pro and cons of choosing a host which is not based in your own country?
  2. GibboNet
    GibboNet New Member
    It matters because where your hosts' server is can affect it's speed of connectivity. The more telecomunications backbones in the area (that it connects with) the better the speed should be.
    That's a matter of connection though, not actual location. Physical location itself shouldn't matter at all, as long as the server itself is well cared for.
  3. tongyun
    tongyun New Member
    If the infrastructure is present and well maintained, then it shouldn't be a big issue. The key is whether or not the company that is supporting you can properly communicate with you if there are problems so you aren't left hanging and wondering what is going on.
  4. andrew25
    andrew25 New Member
    I think it won't be a big problem because we may never know in which country the maximum amount of traffic comes from. Further if the hosting servers are well maintained and adequate there is nothing to fear if the hosts is in different country.
  5. cirereyes
    cirereyes New Member
    One advantage is that, some countries offer it cheaper than the ones offered locally. One disadvantage is that it will not be cheap to call them up if you really need to.
