Character Encoding
Orrymain
New Member
May 10, 2009
17
I'm not sure if this is the right spot to ask this question or not, so please forgive if it's the wrong topic. I'm in a learning curve right now. I've noticed lately that character encoding on many servers have switched from Western ISO 8859-1 to Unicode UTF-8. Does anyone know the reason why that's happening? What's the big advantage of UTF over 8859?
One difference that I know is that the 8859-1 has more technical support but has less character support. The UTF-8 has more character support but only has a few technical supports.
Thanks for the reply, and I hope others who are 'in the know' respond with their insights, too. I have just found this transition that has happened in just the last few months to be very annoying. Instead of quotation marks, I now see question marks. So, depending on what character encoding has been used, I have to manually switch it on each page. It's a real pain.
In my experience, UTF is more widely used, so this is a better choice, and also why your new host is using it, though you could try asking them :)
A character encoding is a method of converting bytes into characters. To validate or display an HTML document, a program must choose a character encoding. For documents in English and most other Western European languages, the widely supported encoding ISO-8859-1 is typically used.
