Sender
- Joined
- Mar 9, 2015
- Messages
- 76
Are you in search of reliable and fast Germany RDP?
At Rdpdatabase.com we believe in user experience with better pricing and only try to give you what makes your work done We only use latest and updated control panels to ensure optimal performance. Dedicated Server, VPS and RDP come with full Remote desktop GUI access which is great deal for new users. Multiple servers, from various locations and different datacenters with the cheapest pricing on the internet. The core of our network is setup with redundant Brocade MLX routers with IPV4 and IPV6 support. The network is connected to multiple redundant 10 Gigabit fiber uplinks to guarantee a 99,9% uptime. Choose from the best configuration from basic to advance and custom configuration is also available via support in case if you need particular configuration just let us know.
Check out Rdpdatabase.com Linux Germany RDP Solutions:
OUT OF STOCK Germany RDP at $4.95/month
1vCPU
1GB Memory
12GB NVMe/SSD Storage
1TB Bandwidth
1Gbps Connection
MINIMUM REQUIREMENTS Germany RDP at $9.95/month
2vCPU
2GB Memory
30GB NVMe/SSD Storage
3TB Bandwidth
1Gbps Connection
GROWING Germany RDP at $19.95/month
2vCPU
4GB Memory
60GB NVMe/SSD Storage
5TB Bandwidth
1Gbps Connection
Best Value Germany RDP at $36.95/month
4vCPU
8GB Memory
140GB NVMe/SSD Storage
7TB Bandwidth
1Gbps Connection
Take a look at Rdpdatabase.com Windows Germany RDP Solutions:
2vCPU
2GB Memory
Virtualizor Control Panel
1Gbps Connection
2vCPU
4GB Memory
1Gbps Connection
4vCPU
8GB Memory
1Gbps Connection
BEST PERFORMANCE Germany RDP at $69.95/month
6vCPU
16GB Memory
250GB NVMe/SSD Storage
1Gbps Connection
We Provide Remote Desktop Services with these Benefits:
Easy to Manage - All servers for sale come with a user-friendly control panel for easy server management. Keep track of all your resources live through the dashboard, and make necessary adjustments as you go.
Easy to Expand - If you need to upgrade your server environment because you require more resources, you can send us a ticket. There is no need to transfer files. We can help with the upgrade and it often finishes within a few minutes.
Server Level Protection - Automatically DDoS detect & mitigate any type of attack at layers 3-4 & the application layer. Full-Network Protection. Stop Bot Attacks. Easy Integration. Strategic Sinkholes. Trusted Globally.
Max Performance - All our plans are designed to give you the best performance possible.
Money Back Guarantee - If you’re not completely satisfied, simply cancel within 24 hrs. Please Read Our Refund Policy for all details.
Multiple Locations - We have added multiple location options so that you can select the one that is closest to you.
1vCPU
1GB Memory
1TB Bandwidth
1Gbps Connection
2vCPU
2GB Memory
3TB Bandwidth
1Gbps Connection
2vCPU
4GB Memory
5TB Bandwidth
1Gbps Connection
4vCPU
8GB Memory
7TB Bandwidth
1Gbps Connection
2vCPU
2GB Memory
1Gbps Connection
2vCPU
4GB Memory
1Gbps Connection
4vCPU
8GB Memory
1Gbps Connection
6vCPU
16GB Memory
1Gbps Connection
