Releasing a domain name
webhostingnovice
New Member
Feb 22, 2006
3
Hi all,
I am new to web hosting adn doing it on behalf of my friend. I have a web hosting site and a customer reqests me to release hid domain name. Please suggest me the steps in releasing a domain name.
I would really appreciate your help.
Thanks much in advance,
Webhostingnovice
Go to the registrar of the domain, there should be a checkbox like
"Registrar-Lock
Do not allow this name to be transferred to another registrar."
If this checkbox is active he is not able to transfer the domain to a new registrar. Simply deactive it.
Hello Walter,
Thank you very much for the prompt reply. I highly appreciate it.
Can you please let me know where can I find the 'registrar of the domain' section or how to navigate to it? Is it through the CPanel or something related to the Webhostmanager page itself? I am very new to all this stuff,Please help me out on this.It would be of very great help.
Webhostingnovice.
"Registrar-Lock
A registrar is a site like www.enom.com or www.register.com where you buy domains. Even if you buy through your webhost he will buy it through a registrar.
Go to the site of your registrar, login with your username/password (not the Cpanel one :)) and change it there.
Where have you bought the domain?
No problem :)
Hi Walter,
The registrar was godaddy.com
Cheers,
Srujana
No problem :)
So login to your Godaddy account and change the settings described above :)
